Six-point Double Box End Wrenches Exist?
oldschoolcraft
Bay Area, California
Is there any 6 point double box end wrenches on the market? Would like 0, 15, and maybe 45 degree offset versions with two sizes on each end in 6 point. Or maybe a single size, where one side is 15 degrees is and the other side is 45 degrees.
Brake bleeder wrenches are the only ones I've seen that come in double box end 6-point that I've seen and they come in limited sizes. Also they dont seem to come in 0 or 15 degrees.
Through my research I found Napa Carlyle and Snap On both make combination wrenches with 6 point ends, but I dont really need yet another wrench with the same open end on the other side.
tooljunkie4
Maryland
Snap-on appears to have only these two 6PT DBE wrenches in their current (online) catalog.
15 mm x 13 mm
14 mm x 12 mm
Other sizes were offered in years past. For example, I have a 1/2" x 9/16" low-offset wrench in 6PT.
Building out good SAE and metric sets of these has been a back-burner item on my to-do list for a few years already. Will be interested to see how the search goes for you.
mattstevens
Nepros:
Also available as a set:
O
oldschoolcraft
Nepros:
These look perfect, thank you!
bobg03
conway sc
Don't forget 6 and 12 point S shaped wrenches and half moon style. Handy for unusual places under the car.
dchawk81
Your spare bedroom must be a sight to behold. You should make a YouTube tour video.
94EG8
Snap-On used to make 6 point double box end wrenches. I'm pretty sure they were only available in SAE and they're long, long discontinued. But they do show up on ebay.
ricleh
Sacramento, CA
I have sets from KTC, Nepros and Snapon - all metric. The Snapon set is combination open end and 6 pt box end.
Ricky Joe
Roanoke, Va.
Really? Everything I've seen on the forums is that they are kind of useless, and people who have bought them just in case, never used them.
Many obstruction wrenches are special purpose, such as starters, manifolds, exhaust, distributors, head bolts, suspension, etc. Some are specific to certain years and applications, some are multi purpose. I have found the s shaped wrenches very handy, especially the old offset ones, on many occasions. The same with half moon wrenches. I have a drawer with nothing but obstruction wrenches. They are far too useful to ignore.
CGarage
United States/Switzerland
Please post a pic when possible.
Astro_Pneumatic_Tools
South El Monte
I always thought a 6-point double box end offset wrench with the same size on each end would be cool, then you could make the 2 ends clocked differently that way if one end's 6-point design is hitting on something you could swap it around for the opposite clocking position and have the same access as a 12-point.
AJHD
How about 4-way angle wrenches, but with 6-point box ends instead of open ends?
