SIXTY4's VETTE GARAGE.......A FEW PICS
sixty4
CT
Its been a long cold winter thats for sure! Anyway wanted to post some pics of the new home for the Corvettes. After so much BS from the City looks like spring will be here soon and will get the 40x30 finally done.
Junkman
Northeastern CT
I like the look. Did you buy the plans, or were they drawn by an architect? What state are you located? This is along the idea of what I would like to have built. Cost is a big factor for me now that I am retired. thanks Junk
larry4406
Northern Virginia
Very nice - do the dormers act as skylights? I like the bump outs on the ends; are these for work benches and/or equipment? I noticed that your OSB sheathing has some rather generous gaps in them. I would block them closed with a 2x4.
sixty4
CT
Yes the bump outs will serve for work benchs and also adds a detail as not to just have a square box. We did block the gaps off. We have skylights (3) along the back and make a huge difference, again the dormers do help but are more to break up the roof.
Hi Junkman, We are in the same state, I am south of you in Stamford. I drove around and looked at every garage I could find and came up with this one. I use a guy from Ridgefield CT and he drew it up for us.
Yes the glue lambs were a PITA not to get in place, but to have the truck get down the street to make the delivery! Once on site we slinged them into place with a small crane my friend owns. It actually has been the saving grace of the job ( build it crane it up nail it off).
Thanks guys!!
rlme36
Nice design, what are the overall dimensions and the ceiling height?
I hear ya on the city located in CT too, and conservation was a PITA for me. build is close to a small stream
tcianci
Walpole, Ma
Beautiful looking frame!! And a great size. What do you plan on using for siding material? I know everyone will laugh at me but I wouldn't use Tyvek on a doghouse. I'm a remodeler and have had ocassion to work on buildings that have used Tyvek as an air infiltration barrier. Tyvek lets water vapor pass through it. Everyone thinks that's great and it is if the water vapor originates inside the building and gets by the vapor barrier of your insulation material. My observation many times has been that wind driven rain that can get behind a siding job, especially loose stuff like vinyl will turn to water vapor as the sidewall is heated by the sun and the water makes its way through the Tyvek and TOTALLY rots the sheathing out behind it. No joke guys, I have seen it many times. If you look at the deterioration, it is worse right behind the Tyvek and then lessens at the backside of the sheathing and continues to lessen as you move toward the inside of the building. One job I repaired required the total removal of the siding and rotted sheathing right down to the studs and some of them were shot too, especially at the corner boards even though the actual sheathing was wrapped with 2 layers of Tyvek at the corners where the material was overlapped when it was applied. Do yourself a favor and apply good old roofing felt instead. I have taken apart hundreds of old jobs where the building was wrapped in felt or rosin paper and seldom if ever find the disaster I have seen under Tyvek jobs many years newer.
Just my 2 cents
sixty4
CT
Going to use Hardy Plank. Paint the ends at every cut leave the gaps at the ends and caulk. I never heard that about the Tyvek, years ago they did use tar paper. Hope I never find out! :beer:
Old61
There's a garage with style!
What are you using for pumped in heat thru the window?
tcianci
Walpole, Ma
Hardie plank is great stuff!!! You can cut it with a special carbide blade or an electric shears made especially for the material, the shears are a zillion times quieter and make no dust. I have done several Hardie Plank jobs recently. Buying the product completely pre-finished is the way to go and I believe it also provides you with the longest finish warranty. If you go pre-finished, be sure to use the color-matched caulking made to go with it, the match is usually perfect. We always have a gallon of matching finish mixed up and pre-paint the edges of the corner boards and the inside corner fillers so that there is no need to apply paint to these surfaces after the siding is applied. Just like anyother painted product, the stuff you have mixed will show up if you get it on the pre painted siding, so painting those surfaces first makes everything look perfect. Go easy on the caulking too. It removes with paint thinner but if you slather up the ends of your planks and then attempt to clean it off after you **** the boards together, it leaves a residue that looks like smeared paint when viewed from certain angles. Also be aware that although the application instructions mention a gap between the plank ends, it also says that the gap is not necessary, I believe it says something like 0-1/8 inch or something like that. We always **** it tight with just a slight amount if caulking at the joint. Don't skip the nailing of the **** joints on the face of the product unless you use some of those new clips made for the purpose. Blind nailing with roofing nails along the top of the course works out great especially if you use a roofing gun. At the **** joints we usually add a strip of 15 lb felt about 2" x 6" installed vertically as a flashing strip to keep wind driven rain from getting through the siding job, just slip it under one edge of the siding, letting it lap over the top edge of the previous course and the **** the other board into it. Stainless steel ring shank siding nails do a great job at the **** joints but you need to pre drill the stuff with a carbide bit first. You should be very pleased with the result and the long term durability of this stuff
lethal-6
Lascassas, Tennessee
Great garage.How tall is it? Also is their going to be an upstairs area or an open ceiling? I look forward to seeing the finished product.
Omphaloskeptic
Ultima Ratio, Wa.
The vettes should be very happy in their new home. Very clean traditional look; love the gable end treatment and bump outs. Have you picked out your door style yet?
