My rule of thumb is to use the largest sized lines that you can reasonably afford to purchase. There is no such thing as a line that is too large. The larger the line, the less the resistance to the air flow, and the greater the storage capacity of air. Assume that you have a 60 gallon storage tank, and that the air line that you use has the capacity of an additional 10 gallons of storage (hypothetical), then your total storage capacity of the system is now 70 gallons. The two things that you always must consider when using air is the total CFM (Cubic Feet Per Minute), and total pressure at the CFM. Most air tools are rated this way.... ** PSI @ ** CFM. The best tool in the world will not work well, if it is starving for PSI or CFM.
