My installer (good friend) did mine for beer
He used Rigid brand tools for the flaring on the lines. There is a spec in the install instructions on the max/min length for the line set. If the length is below spec a little freon needs to be purged from the system. IIRC (my system) if the length of the refrigeration lines exceed 65' you add 0.27 oz freon per foot. He did a leak test with nitrogen on the lines and evaporator unit (indoor). Next he pulled a vacuum while we enjoyed a cold one... then opened the service valve on the pre-charged condenser (outdoor) unit to charge the rest of the system.
I bought the copper lines from Home Depot the morning of the install and only used 20' out of the two (5/8 1/4) 50' boxes. If I would of waited another week I could have ordered the pre-fabbed 20' set with flare nuts, already insulated, with a drain line and low voltage wire... all wrapped in a purty package for the same price I dropped on the raw copper.
Can't complain though, everything went very well. I spent around $200 on wire, conduit, copper, 30A breaker, disconnect and beer
