JohnCh
I need some advice on sizing a radiant tube heater. After going through a lot of very useful threads here, I’m leaning towards the Reverberray LD-series, dual stage heater, but I’m conflicted over which size to get for my 28x45 shop with a 9'4" ceiling. The longest tube option for the 40k/28k burner is 20’, whereas the 50k/34k burner is available in a 30’ length. My conundrum is that I’m concerned that at even at the lower setting, the 50k may output too much direct heat for my taste (I prefer being cold to being hot), but that is countered by concern that a 20’ tube won’t provide enough coverage given that my workspace will occupy the full length of the shop. If they offered a 40k/28k with 30’ tube, I wouldn’t be posting this, but they don’t. The person at Reverberray said that I won’t notice the 6k difference between the lowest settings of the 2 units, and suggested I optimize for length with the 50k 30’ heater. What do you folks with tube heaters think is the best compromise?
As further background, I’m located about 30 miles Northeast of Seattle, so weather is not extreme. The average low/high temperature in the heart of winter is 33F/44F, but it’s not uncommon to get several days each winter where the overnight low is in the low-mid 20’s and the high is around 30F – of course I doubt I’ll be working in the shop on those days. I plan to keep the shop at ~40F when not in use, and heat it up to 60F-62F when in use. The ceiling and 2x6 walls are insulated with fiberglass batt insulation of unknown R-value. The tube will be located parallel to the long wall at a 45 degree angle.
Thanks,
John
Thanks,
John
