Sizing motor for air compressor build
Ike Carlson
Wisconsin
I'm building an air compressor for my shop. I have a vertical 120 gallon tank(great condition), and four more 25 gallon tanks to put around the shop or use for quick detach portables that stay charged when connected to the system.:bounce:
So I have a total of 220 gallons of storage. Total cost $40:thumbup:
I will be using a cooler and wet tank to dry the air.
I picked up an Emax 5hp 2 stage compressor today for $10, no joke. I tore it down and the lower end is rusty. I will clean it up and put new bearings in it. It's a good unit. This thing weighs a couple hundred pounds.
I have a 3hp 3phase motor that runs on a vfd. I have air tools (impact, wrench, drill, etc) and a small sand blaster. I figure 220 gallons should be plenty of storage, but I would like to keep up on air as much as I can. The numbers I have found say I can get 12-15 cfm @100 psi with my 3 phase motor.
I don't know what rpm the EMAX compressors are rated at. (850,1000, etc...)
Does anyone know or do I need to call them on Monday?
I believe this one is a 20 cfm model, so if I know the rated rpm I can reduce the rpm to match the motor.
I have an unloader already, and will be putting it on the compressor.
If anyone can help my with the motor size/rpm or has any tips, please let me know. The motor will run to at least 3500 rpm safely according to Leeson, if it needs to run faster with a smaller pulley. (I want to say it was close to 5,000 rpm max rated rpm.)
