edl
We have enclosed a portion of our warehouse into 2 roughly 40x40 sections - 3 of the walls are outer walls (block...no insulation) so 2 40' sections and an 80' section and the wall we built to close it off is 2x6 batt insulated that is 80'- ceiling height is 14' - ceiling is metal and is spray foam insulated...maybe an inch or 2 in thickness
we built another stick frame wall as the divider, with an 8'x7' roll up door separating the 2 spaces
I am trying to get a sense for what size a/c i will need and whether a minisplit diy can work in this set up?
the thought is one unit that can do both sections at once and have each be a separate zone? - or would it be more economical to run each as its own zone with own closed loop system?
(i realize many will want to say insulate the block and insulate the ceiling more...feel free...but i know)
thanks!
thanks!
