goofiefoot
For those following, I'm in the process of building a 10x20 Tiny Workshop in my backyard. I live on the south Texas coast, so heat and humidity are pretty much a constant. In designing my shop, I elected to have a window-style AC unit, rather than a mini-split for ease and cost of replacement - the salt air down here is hard on ACs and they don't last very long. I'd rather replace a $300-400 AC every 3-4 years than an $1800 system every 5-6 years.
The shop is 200 sqft with vaulted ceilings (about 11ft at the interior peak). I will be insulating the walls and roof area, and have installed radiant barrier OSB as the roof sheathing. There are two small windows and a windowed french door. The building is fairly well shaded by the oak trees in our backyard. Plugging this all into a typical BTU calculator, I'm showing the need for around 10k BTUs - which is easily obtainable in a 120V window AC.
The question - given the factors of possible "extreme duty", should I oversize the BTUs for my situation? Would running a 12-14k BTU unit do anything more for me than the 10k, or would those simply work less and negate the dehumidifying in this space? I do plan to keep the unit running to maintain temperature and humidity.
Any thoughts are helpful!
