Ramper
My wife ran over my good cord last night with the mower (FIL left it out). I see that Lowes has 250 feet of 12-3 SJOOW for $75. Could I just buy that and some nice plugs and make my own cords?
Actually, it appears they may be allowed
At $0.30 a foot, I think I could splurge for quality ends and have some nice extension cords. I would probably only go with 15-amp ends (maybe 20 amp)
... If I were using it outdoors, I'd spray the connections inside with WD-40.
Only for personal use, made up ends are not legal for commercial/professional use.
I believe so, with some exceptions (hospital grade cords for example MUST have cast ends with clear plastic so you can visibly confirm the status of the connector).
Installed cord ends are a little more susceptible to corrosion when exposed to the weather. If I were using it outdoors, I'd spray the connections inside with WD-40.
But, you may find that you're not saving too much. Cheap plugs ****. Good plugs (I LOVE Hubbel) are expensive, and good connectors (the side opposite the plug) are WAY expensive.
If that were the case, the very large corporation I work for would be in deep doo doo! Every cord we have is made up. All twist lock connectors. Most have Daniel Woodhead "boxes" on the ends with twist lock receptacles on both sides, but NOTHING is "store bought".
Charles
