SK C-series raised panel wrenches
One-Zero
Ok so I have been compiling all my extra tools and saw that my polished SK wrenches are marked S-K or S•K so I pulled out my C-series and saw that they’re S-K, S-K tools, sk lectrolite, or sk wayne and on top of that some are stamped on the opposite side so if I put them in a rack or hang them they don’t match. Now my OCD is barely accepting the -vs• but the C-series is unacceptable! How do you guys differentiate between the styles to get a matching set and are these collectible enough to trade for the polished ones to get my modern set to match?
My situation is pretty much the same. I’ve found some complete sets which keep like wrenches together. I don’t look for the more modern ones but sometimes they find me.:headscrat
O
One-Zero
I see your 3/8 is a 6 point but is the correct part # sequence for the set just like my 7/16. Was it the common practice for the smaller sizes to be 6 point?
I guess I’m going to sell the lot and put it towards building or buying a full matching set.
Sometimes when I find sets at the flea or estate sales they are missing some wrenches. My large S-K Lectrolite set was missing a wrench but I had one on hand that allowed me to complete the set. I would suggest hanging on to the style that you are most interested in. I personally don’t keep the S-K Wayne tools but others collect them.
I think that smaller combos tend to be 6 point to minimize potential for rounding off the nuts or bolts.
DadsTools
A few years back I conducted an extensive research on Lectrolite Corp (LC) and found a lot of info on S-K in the process. The info is scattered in various places on the Vintage forum, but I'll recount what I remember:
--Lectrolite re-designed its 1st tier end wrenches to the now-familiar raised panel style sometime in the late 1940s. These were to become the S-K line of wrenches. They will be marked LECTROLITE and are identical to the later S-K. My main set of SAE end wrenches are 1951 LC.
--In 1952-53, LC established a relationship with S-K with its end wrenches and pliers, which S-K did not manufacture itself (it was focused primarily on socket sets). This relationship continued until 1962-63, when Symington Wayne purchased both S-K and LC, then eliminated the LC brand and absorbed its products/facilities into S-K. These collaboration wrenches bear the mark S-K LECTROLITE. LC stopped marking these raised panel wrenches with its own standalone name, so any RP wrenches with just the LC name are circa 1947-53, and the dual-marked circa 1953-63.
--Under the Wayne ownership, the wrenches are marked S-K WAYNE. Circa 1963-68. For the most part, their mfr is identical to to the LC wrenches.
--Ownership passed to Dresser Industries in 1968, and the wrench markings were changed to S-K TOOLS. It was during this time that they started playing with the finishing and other markings like removing the hatchings from the sockets. QC issues became more of a problem during this period. Although I've never done a case study on which side of the wrench was marked with the brand, I'd suspect this mixing-up would be more prevalent during the DI era. IMPORTANT NOTE: One of the marking changes under DI was the changing of the "C" in the model number from an 'open-C' to a 'closed-C'. This provides another clue to age.
--In 1985, DI sold S-K to Facom Industries. I did not do any extensive research this late because my focus was on the earlier production. I believe it was at this time that the marking was changed to simply "S-K", but could also have happened later in the DI era, I'm just not certain. These can be easily identified as later production by the closed-C.
I believe the "S-dot-K" was introduced by Ideal Industries. Before then, I think it was always S-dash-K. I also think that the full polish S-dash-K were made after management bought the company in 2005. It was after the Ideal buyout that it was changed to S-dot-K, the finishing of the full polish wrenches is noticeably better on the S-dot-K versions.
Hope this helps.
toolmutt
Texas
Both of my complete sets of vintage SK combos were six point up through 7/16, then switched to 12 point.
O
One-Zero
Hope this helps.
Wow! Just what I was looking for! Thanks!
DadsTools
BTW, I just checked my 1951 LECTROLITE set, and the 3/8 and 7/16 have 12-point boxes. So somewhere after the S-K collaboration, the sizes below 1/2 were switched to 6-pt, but I'm not sure when. Every S-K marked RP wrench I've seen with no Lectrolite mark) were all 6-pt below 1/2. The 1955 Lectrolite catalog listing S-K/Lectrolite wrenches in the C series states all sizes are 12-pt, and list no sizes below 3/8. The 1961 jobber catalog, the cover of which now displays both S-K and Lectrolite names, has the C-series open stock also specifying 12-pt for all sizes and also does not go below 3/8 in size. Both the 1964 and 1965 S-K Wayne catalogs (no more LC) are the same for C-series (3/8 smallest, all boxes 12-pt). But I also have examples of S-K Wayne in the smaller 1/4 and 5/16 (sizes C-8 and C-10) with 6-pt openings, so at some point Wayne added these sizes and perhaps the switch to 6-pt below 1/2 was made then. Which, BTW, may make one version more rare than the other.
That's all I have on the 6-pt/12-pt question.
DadsTools
:thumbup:
Over 90% of the time, someone in these vintage forums has detailed info on just about every brand out there. Now once in awhile, someone does come along and they "stump the band" but not very often (I've stumped the band a few times myself).
