Skat Blast cabinet vacuum upgrade
TwoNoneFab
Have a large Skat Blast cabinet i just upgraded the gun to the one that consumes 25 cfm of air. I have the regular skat blast vacuum but after 30 seconds I can no longer see. Looking for a cost efficient upgrade would love the large reclaim system they have but $2500 is out of the budget. Would love to stay under $500. And insight
OccupantRJ
Eastern North Carolina
Using glass beads at 110 psi
Back off to around 80 psi.
check out my abrasive blasting thread. More than you ever wanted to know in it.
OccupantRJ
Awesome I will get a regulator and back off on the PSI thank you for your help
You could also try 60 psi as long as it will abrade for you as you desire. Play around with the pressure. Also be aware that on a siphon type gun, the air jet in it determines air consumption, not the actual blast nozzle. That determines blast pattern more.
T
TwoNoneFab
This is the setup I am using.
bb29510
wondering if you could use a small squrrel cage into a seal bucket with water, to pull the dust out
