6530
I recently picked up a benchtop drill press & a Grizzly mini mill, and I want to mount them both to a mobile table so I can roll around and store easily. I had some thoughts and decided to use Sketchup to see what it would look like to scale. I also plan on picking up a metal cold saw (chop-saw style) so I wanted to see how it would fit also.
The results, after some time learning how to use the program and then doing the design:
It's designed to fit in the space I've set aside for it (approx. 32Wx24Dx30H). It's got two vertical hitch mounts on the front, one for a vise & the other for a grinder.
A few details that I still have to add are a shelf on the bottom where the saw sits and a folding surface extension in the back supported with brackets like these.
The big empty box on the right approximates the envelope I'll need to operate & maintain the mini mill - it'll mount 90 degrees compared to the drill press (the back of the mill will face the side of the drill press). Since I'll be able to roll the table around the mill table can hang over either end.
This took a few hours to do, but even for something this simple it's been a huge help in visualizing and figuring out what will work.
