xtremek
So the wife wants to raise ducks
and I need a place to get the lawn and garden supplies out of the barn. As you know if you've read my thread, the late Fil left enough lumber to build a 14'x 26' shed/room. I'm using sketchup to see where the new building will look the best. I started with the Google map photo since the house and barn are laid out at goofy angles to each other. I did a quick build of the house and barn, but when I try to rotate the barn around one of the bottom corners, the whole thing starts twisting.
At one point, part of the roof was under the ground level.
How do I rotate the entire barn around one verticle corner? I need to rotate it about 30degrees.
