I poured my slab inside of the stem wall. I designed the building so the stem wall would be 3.5 inches higher than the slab. So after the slab pour, I just made a wooden dam where the garage door is. I then wet the slab with a hose slowly running for 7 days. I also covered the slab in plastic to slow the evaporation of water down. My slab is level, so the water just sits there.
I used several thousand gallons of water, but the water cost is nothing compared to the concrete cost, so I did not worry about that.
I read this on the
www.concretenetwork.com:
"Allow The Time to Water Cure
After concrete is placed, the concrete increases in strength very quickly for a period of 3-7 days. Concrete which is moist cured for 7 days is about 50% stronger than uncured concrete.
Water curing can be done after the slab pour by building dams with soil around the house and flooding the slab. The enclosed area is continually flooded with water. Ideally, the slab could be water cured for 7 days. Some builders on a tight schedule water cure for 3 days as this achieves approximately 80% of the benefit of water curing for 7 days.
Consider planning your job to pour at the end of the week, build berms, then flood over the weekend. You get the benefit of water curing without losing too much time in the schedule."
goodluck...
