Daddydavesr86
Purposed Building is a 16x32x12 pole barn in centrel ky.
Based on what i have read my slab elevation should be min 5 inches above grade? Just kinda confirming. Shop location end of a driveway. Driveway slopes down diverting water down and away from house towards one corner of the new purposed shop.
Building overhang?
Do i need one? How much? More for looks than rain control?
Can i install gutters with out over hang?
Do i need a frost wall? Im in centrel kentucky.
Im planning on having a pole barn built. Builder plans show 18 inch diameter hole with 9x18 footer plus 45 inch back fill sand and gravel compacted then that would put height of bottom concrete slab. Then 4 inches of slab.
Vapor barrier concrete? Is this installed on gravel base prior to concrete? Or under gravel base?
Building overhang?
