Steve from Socal
I am trying to get a sense of what I need and about what it would cost to put in floor heat in a building.
The location is Hutchinson Kansas, the building is 6000 sq ft steel frame with brick walls on two sides and steel panels on the other. The building is 60 X 100 and is oriented with the gables north and south. The brick walls are the north and east walls. The building will be 18-19 feet at the eaves with 3-12 pitch open ceiling. The walls will have R-19 and the roof will have R-19 or better.
The floor will have to be thick enough to support a forklift with at least 1000 per inch of tread load. The floor will also have 12 foundations for the steel frame and bridge crane. The floor will also be poured inside an existing stem wall. The building is open on the south and west sides, it abuts other building to the north and east.
The building will be in use daily and a shirt sleeve environment is the goal.
What effects do the foam insulation have on the slab with regards to weight bearing? The slab will require a fair bit of steel, will the foam require additional steel? Is slab heat going to be able to do the bulk of heating or will the slab heat be marginal due to ceiling height?
The project will start in early April, I could use some good info on this application.
Steve
Steve
