I am most likely going with an elevated slab on grade for my 18x24' garage / barn so that I can keep the framing wood & siding at least 8" above the finished grade. The only place that this seems to present a challenge is at the overhead door (or perhaps carriage door if I go that route). This area will need some kind of ramp or apron to get a tractor up the 8" above grade but how do folks detail this area so that water does not get in and how is moisture managed for the wood structure in that area?
Is it a big enough concern for wooden framing that I should go with footings, stem wall and a sloped floating slab so that all the wood is well above any potential pooling or high moisture areas?
Thanks!
Thanks!
