ericm
The concrete guy I want to use for my shop says he usually does a nominal 4" slab which comes out to 4-4.5" as he works to guarantee the 4" minimum. He says he normally puts in 3'x3'x8" footers where the two post lift will go. The lifts I want to use spec 4.5" depth. If you have to cut out a slab because its not deep enough they want a 4'x12'x6" footer. I want to make sure I meet the lift requirements but I'm also concerned about cracking due to differences in cross section. Another option is to ask for nominal 4.5" or 5" for the whole slab, which would be 40x56.
Which is best and most cost effective?
Thanks.
Thanks.
