mopar440_6
Well, the concrete was poured over a week ago in my 50'x60'x14' shop. I will be coating it within the next month (after full cure) but at this point I'm still undecided for the floor coating. It will be a densifier followed by either Nohr-S, Rust-Bullet or SPGX. Pictures of the build can be found here: http://www.garagejournal.com/forum/showthread.php?t=305797
I know these coatings don't require grinding, however, there are still some rough patches from the power trowels. There are little ridges sticking up above the level of the smooth parts that break off relatively easily. I think the ridges are from concrete sludge getting stuck to the outer ends of the trowel blades and slinging off. Also, there are little piles of hardened concrete dust around the saw cuts.
So, my question is how should I prepare the slab without completely opening the pores of the concrete? Should I rent a floor polisher with a 60-100 grit disc and sand it? Should I just try to get a scraper and scrape the concrete until it looks smooth?
I'd appreciate any advice.
