I have a approximate 5% grade to the rear of my lot. I know I will need to grade accordingly. Question is how high above the front grade is a recommended? The rear of the building will be nearly 2 feet above grade. Should a drain tile be considered up front / all the way around the building? Should a retaining wall be considered for the rear of the slab? Build is in SE Wisconsin (Kenosha County). 32X62 (2X6 stick frame).
