My garage is in process.
The plan for the walls is to lay 2 rows wide, 3 courses of brick on top of the slab (monolith) around the perimeter. Then the framing would go on top of the brick. I think there will be some sort of straps that attach the frame to the brick.
However, i'm not certain how the brick will or should be attached to the slab. There are no anchor bolts present. Is mortar between the brick and slab sufficient or should i be expecting something else there?
