boostm3
I moved into new construction about 5 mos ago and am starting to finish the garage. One thing Im wondering about is these slightly slanted cement floors found in new construction today to assist water evacuation. I dont know the percentage of slant, but if I release the emergency brake on the car it will start to very slowly roll backward toward the garage door, and a bubble level confirms the slight slant.
What kind of consideration do I need to give this floor situation when considering open shelving? Im likely going to go with some kind of basic 72"H x 36"W x 18"D shelves x 2 side by side to start.. Each unit will come with 5 shelves and I will use them such that the units will be facing perpendicular to the garage door opening, ie, such that the slant downward goes from right to left as you look head on at the shelves.
The shelves have no leg level adjusters and are about as basic as you can imagine. Im thinking either just use install them and use them, or, perhaps if needed, shim them a bit. Aside from the top of the shelves being at a slight angle when viewed against the junction of the wall and the ceiling, do you know of any structural or other types of issues these shelves might be prone to given the slight floor slant? Thanks.
