Denwad
I work with equipment where in order to remove and replace certain components I need to use very small screw drivers around blind corners, and a thought occured to me
if the shaft of the screwdriver had a small sleeve around it, you could just put the sleeve over the small screw that's holding the data connector on, and then turn the screwdriver until it indexes, and it won't ever slip off 50 thousand times causing you to have to reindex the screwdriver to the screw.
does such a tool already exist? or maybe something i could make myself
