Innovate1
I am putting up a detached garage with a half bath so need electric, low voltage, natural gas, water and sewer (line to existing septic). Will likely go under the footing with most of those and come up inside the building to keep the outside looking clean. The exception may be the gas which may go through a side wall.
Is 160 PSI black poly adequate for the water? Don't know if I can bring this inside the building. Have seen they use thicker into homes here. Think it is 200 PSI that uses compression fittings.
On the conduits and water I think using sleeves slightly bigger than the final pipe/conduit would keep the final line out of the way of foundation work and eliminate joints there. Is sch 40 PVC a good choice for sleeves? For the sewer Not sure if I need 3 or 4 " but if 4" I have some scraps of 6" but it is thinner material. Might block out just above footing for sewer but have plenty of drop so probably easiest to just go under the footing.
Also am adding a gravel drive to the garage and crossing some existing lines - sprinkler, phone, water, gas, high voltage underground feed to utility transformer. Water, and high voltage is deep - at least 36". Phone is similar because it got put in with the water. Not sure how deep the gas is. Sprinklers are only about 6-8". Doing gravel because the road location may change a few years from now. Which of these do I need to sleeve? Sprinkler is easy - it's shallow and easy to splice. I don't really want to add the splices needed to sleeve the others as it just adds a point of failure.
I can talk to the gas and electric utilities. Other lines are mine. I can throw a pipe in where the phone line would go if it ever needs replacement.
I need to put a small culvert in one location. Not draining a large area. Probably use a 6". How deep does this need to be to avoid crushing? Will have some concrete trucks for foundation.
