Sliding gate opener selection
Mesozoic
Tucson, AZ
I've got a 10' steel gate that intend to motorize and will need to figure out motorization soon. At the engineering lab I work at, we installed a Nice Apollo gate opener unit for a significantly larger gate. It has been a good perfomer for the better part of a decade. I see that the same manufacturer, Nice Apollo, has a model 7251 slide gate opener (post-mount) - has anyone used this unit and have anything negative to say about it?
You can see the gate in the back behind the airborne worker below.
ericm
Southern Oregon
We have a Door King 9050. It's been reliable, and it opens the gate faster than the last opener we had. Beware putting the heavy steel lid on though, it nearly took a finger off.
Mesozoic
Tucson, AZ
Thank you providing some feedback on openers you've got experience with. I looked at Doorking, Eagle, and HySecurity - and found many more as well. As this gate is not the main entrance to my building or residence, my needs for it are pretty basic. That being said, I really don't need solar power or battery backup operation which appear to be very common options for slide gate openers.
Has anyone heard of Ramset? They have a model named RAM 50 GB which seems very well priced. The other contender I'm looking at is the Linear Osco GPX-SL25 (also seen this as the GTO GPX-SL25). Both units are priced under $1000, are USA made, and have a range of accessories (I'd be interested in a keypad for access control).
nadogail
Coronado, CA
Most of the Chain Drive openers I have worked on were very old but adequate for the purpose. I don't remember their brand names
It has been years since I retired from that line of work.
Mesozoic
Tucson, AZ
Thanks, all.
What is the consensus on DIY installation? The only reason I am considering DIY is because the quotes I've received from local contractors for the unit + system installation is between $4-5K. I'm finding that a bit steep based on the fact that it's not a primary entrance and will be very infrequently used. I don't really need it, but I figured that I'd be looking at a few hundred dollars for installation rather than an extra $2000-3000 on top of the cost of the unit.
tarmy
Nor Cal
I am installing my replacement operator this week. My GTO crapped out after almost 12 years. Going with a commercial grade LiftMaster.
Removal of old and new install will probably take a few hours...with all the new required safety systems.
OP...the original install is more complicated...power, ground, alignment, underground conduit, concrete base and all the rest...I could see a grand...maybe a bit more depending on your site specific conditions/details.
If you are handy...just do it yourself...not really that complicated...
Mesozoic
Tucson, AZ
I think I will wait until the driveway is poured (tomorrow) and everything else is finished - then, once the weather cools a bit, I'll see about installing a unit myself. Thanks!
tarmy
Nor Cal
Get a couple 1” conduit under that driveway for comms and lighting...or whatever...
I always put down a few electric, a water and a 3” ABS for whatever may come up. I end up using them for all kinds of projects...
