I should have added that the garage door is to be added to my walkout basement -- which doesn't have a high ceiling -- so height is a bit of an issue with a standard roll-up door -- and so I'm looking for alternatives.
If this sliding door is not the solution to my needs, what is?
Thank you to everyone for your input. Please continue.
Although clever, I would think the track in the slab would fill with debris impeding motion, would be difficult to seal at the bottom, and now the entire wall is lost as a storage option meanwhile the ceiling is unused.
I hadn't thought of the debris issue -- so thank you for that tip.
I wonder how the sealing issue on the bottom compares to the sealing issue on the sides of standard doors.
There goes 1/3 of your wall space.
You have quite an eclectic collection of vehicles!
Since one side wall would not be used for storage anyway, that's not really an issue.
As for my little stable of vehicles, it is true that I like both oddball cars and time capsules.
One would have to believe that this system is not popular for a reason.
Though that thought occurred to me, I believe that people sometimes follow the "we've always done it this way" philosophy.
I went through this same dilemma. I decided to build some swing out carriage doors. I will probably start on them next weekend.
I'll be anxious to see a "build thread" on your project.
I could see where that style of door would work out. If the design/layout of the garage door opening is right up against a wall it would work perfectly. In other words if there is little space for cabinets/storage on the wall where the door would be.
As this is a garage door in my walkout basement, the opening is right up against one wall. That side wall will not have storage.
Unless you have a snow/ice issue, they could slide on the outside of the building.
Though I like that idea, it wouldn't work on this property.
