So my garage is a 24x24 double detached. 8' high door on one side and a 10' door on the other side. I have attached a quick layout that I made so you have an idea what I'm talking about and how the shop is laid out.
I want to build some sort of rolling or sliding partition wall down the middle to help contain dust/grime and heat.
I will be using the side with the low ceiling as my workshop/clean(er) area and the high side where I will do my welding/cutting/vehicle work etc... (the dirty stuff).
Primary heating is a wood burning fireplace (I know, not as fancy as hydronic in-slab but I like things simple and I like getting firewood). In the winter it can take a long time to warm the garage and I find I often don't need to heat the whole thing if I'm doing just little work on the clean side at the bench or something.
Any ideas where to go for hardware to build such a thing or any ideas on how to make this work? It doesn't need to be thick and insulated and soundproof... Just easy to extend/collapse and it should ideally have a decent seal on it.
Thanks!
Mark
Thanks!
Mark
