Sliding T handle
e_d
Oregon
I was wondering what are the advantages to having a t handle.
also how do you post a picture.
thanks
Dave455
Sussex, England
Well basically you can spin it, to spin down a fastener really fast!
Some years back, the ever innovative Blackhawk produced a Sliding T that was 'ball ended' so you could spin it that much easier! I'm not aware of any manufacturer that produces such a thing now though!
To post a picture, click on the box at the bottom marked 'Go Advanced' and it brings up some other options, including one marked 'Attach Files'. Click 'manage attachments' and you can search your files for the pic you want!
elcom
Houston, TX
I have the Sunex T-handle spinners (3/8 and 1/4) and am pleased.
Like previously mentioned, you can turn the fastener quickly to loosen or tighten.
The only disadvantage that I've encountered is that you can sometimes inadvertently move the sliding hand grip (that moves up/down along the shaft). Other than that, nice tool(s).
http://www.amazon.com/Sunex-9727-Adjustable-T-Handle-2-Piece/dp/B003XIJ8FE
LXCam
These things are a mixed blessing. It's the greatest thing since sliced bread when YOU NEED to slide the handle over for clearance. But you'll cuss that thing to no end when you don't need that ability and it's always sliding the wrong direction. Make sure you get one with a good solid detent.
G1GRANDEUR
for bolts and nuts that require light//medium torque, way faster than ratchets.
malibu101
Walnutport PA
I have a T-handle and it is in the seldom used catagory for me.
I have used it where I needed to go back and forth between tighten and loosen on a nut/bolt to make a final adjustment without the need to flip the lever on a ratchet back and forth.
jmm
NC
I use mine when speed is key and there's lots of repetition. A few instances when I might use a t-handle would be assembly (running down nuts/bolt before final torque), oil/trans pans (ditto), and small engines (high torque isn't necessary).
As mentioned, a good detent in the middle is crucial. Otherwise they can be a pain. Old Ferret kit Snap-On t-handles are abundant if you don't mind used...cheap too. They're good tools.
Scout Driver
South Dakota
This right here ^^^^^^. 100% agree. :thumbup: I even have an old Snap-On Ferret t-handle.
Put a comfortable length extension between the t-handle and socket and you have a speedy, efficient tool.
I also use a t-handle for running thread chasers. It works well and enables the use of an extension if needed.
Scott
Scout Driver
South Dakota
As far as posting a picture:
When you are replying or starting a thread, go under the Additional Options header. Below "Attach Files", click on Manage Attachments. This allows you to pick a picture from your files.
Or, you can link a picture from a photo-sharing site such as photobucket.
Scott
jmm
NC
Scott
Well sir, you finished my incomplete thought. Normally I use about a 3" extension and deep well sockets. A decent (tight) u-joint is handy to add to the mix if you're working at an angle.
foreverfalcon40
Faster then a Fine tooth ratchet or a ratchet in general?
Only "T" I own is for my 3/4" Set and I have still yet to use it (THANK GOD). I thought it was more like a breaker bar.
E
e_d
Oregon
Do you mean like this.
E
e_d
Oregon
Furthermore I want to thank you all for your answers to a question I have had for hours now.
BD1
north side
I use one for the center roller bolt on my harbor freight tubing roller. Works great.
CRTDI
That's a fairly rare 7/16" drive piece. No slide feature. The position is fixed.
rusty65
Pekin,IL
I use sliding T-handles with universal joints and flex sockets. T-handles make using those kinds of attachments much easier then using them on a ratchet from my experience.
Sent directly from the Snap On Kool Aid factory.
