We moved into a place with heated floors but it came with no operating instructions. It has a Taylor wood furnace outside to heat and circulate the water.
There are lines running to the indoor water heater. They are in the same bundle as the main water supply and return from the outside furnace. The valves are off at present.
The valve plumbing circuitry enables the cold water supply for the indoor water heater) to be diverted somewhere. I guess the two possibilities are that the water would be preheated directly by the wood furnace, or indirectly by the concrete slab mass.
Which would be the most likely scenario?
