Slotted angle for shelving/workbenches
going88mph
Hello,
Spent a few hours searching this forum, and found most DIY'ers here have built their workbenches/shelving from lumber. Not that there's anything wrong with that, of course.
Has anyone tried to put together workbenches/shelving from galvanized slotted angle? You can get some fairly impressive strength numbers from a relatively small amount of material, and it can always be broken down or reconfigured since it uses nut-and-bolt assembly.
So why haven't I found any examples here?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I think there have been a couple members that made benches out of the perforated angle, but not too many. It just doesn't seem to be as substantial for a bench. Plus with a wood bench you can nail it or screw it. If you are looking for something like an erector set, have you ever looked at the 80/20 website? http://8020.net/ You can make quite a few configurations out of it. I think there are two rather large threads about workbenches. I'll see if I can find them and post them up. I have them bookmarked on my other computer but not this one.
Falcon67
Merkel, TX
Lot more expensive per linear foot of support. Harder to cut unless you have a metal band saw. I can bust out 96" x 16" of 2x4 shelf with supports and a OSB top before you could cut the steel with a hacksaw. And bald guy says that when he bumps his head on a wood shelf, he gets a bruise and a headache. Bang an angle iron shelf and he gets stitches. :lol:
hh76
NE Wisconsin
I'd look into strut if I were looking for a bolt together bench. It's a little heaftier, and you can get all kinds of attachments. Just look through the cooper b-line catalogue. Personally, I'd rather use lumber or welded steel.
frankush
IL
I've got about 5 different shelving units that I made out of this stuff. Mine is green. Most all of them are in the basement. It was no where near as expensive as it is today. We had a cutter for it at work and it went together quick. I used 1/2" ply for the shelves. Solid as hell. If I ever move, I'll break it down and take it with.
