Small air compressor vibrates around in circles...
inurface
rochester, ny
Any recommendations to keep my air compressor stationary? It is a small 2-gallon air compressor that has some rubber feet. The problem is it vibrates around in a circle. Bangs the wall or anything near it and messes with the hose.
Chris Adams
Common problem. Easy fix is to get a long bungee cord and put a nail in the wall, bungee the sucker down. That helps with noise, vibration, and doesn't stop you from moving it easily.
Chattah
If it has a hole in the bottom for mounting you could get a pallet and bolt it to that or you could bungee it to the pallet. The key is to add weight and surface area in contact with the garage floor.
duke5572
Council Bluffs, IA
Install a turnstile and sell tickets to watch the Amazing Dancing Compressor.
Maybe its a religious thing for your compressor, like the whirling dervishes displaying their devotion.
Problem solved.
Vulturej
Illinois
I had one that did that years ago. On mine the rubber feet were good so i put a 25 pound hand weight on it, and that kept it from moving around.
