Small couplers?
Sumboodie
AK
Are small "air" couplers common/industry standard??
I have a diesel compression tester, which ends up not working for International 7.3L.
Online people talked about a short adapter that gives the proper clearance between the glow plugs hole (where the compression test goes) and the rocker.
Well, I must have a different kit, because it's not working, it uses a different coupler.
Trying to figure if I can buy a different female coupler or I guess a different guage?
What i have is like a $50 setup, have had it probably 5-6 years and never needed it till now.
Sumboodie
AK
Bought a Lang tool adapter that's listed for the TU-15 kit, which is what I have.
Doesn't fit. Apparently there's several TU-15 kits. Go figure.
Firebrick43
West central Indiana
You could buy the correct air fitting that will work with your compression gauge and use a lathe cut in half and bore a hole in the opposite end. Then turn your mityvac adapters air fitting off and leave a spigot. Put the two pieces together and use staysilv 56 silver brazing and flux to silver brazing together.
