Small Diameter Tubing Bender Recommendation
What's available that has multi-die capability?
Looking to bend 1/8, 1/4", 3/8" and maybe one or two 1/2" stainless tubes. I'd prefer to pick up something like a rigid/swagelok style tubing bender that has replaceable dies but at ~$200-300 each I don't want to spend $1k to bend ~15 tubes.
MountaineerMiner
Check out Imperial Eastman kits on eBay. Good quality, US made, lots of slightly used models available. I paid about $200 shipped for mine, but it is not in perfect cosmetic condition, expect to pay a little more based on condition.
Have not used on stainless, but easily bend plain steel hydraulic lines up to 3/4, possibly larger, just have not tried, should do up to 1/2”ss without breaking a sweat.
454ragtop
Carver, MA
LXCam
I do quite a bit of stainless tubing and you absolutely want the best as you already know. Those cheap cast units **** a dirty set. Some of the best pricing I've found has been from Aircraft Spruce
https://m.aircraftspruce.com/catalog/topages/levertypebendr1.php
But you might also try Zoro and wait for a 25% discount code. If you plan on going bigger then 1/2" I'd suggest this kit. I bought it not long ago and for 200$ on sale is a hard value to beat. But, the shoes will need to be cleaned up of the casting marks as those will transfer into the tubing.
https://racetoolsdirect.com/product...MoUETlQT03EnQUANauMG9p9_PVY-SOzoaAvfrEALw_wcB
454ragtop
Carver, MA
Not sure if you're referring to the RobinAir bender I linked to, but if you are and you haven't actually used one, well, you don't know what you don't know. First, it's not die cast, I agree the die cast ones I've seen are a POS, it glass reinforced plastic. I do a lot of stainless tubing work as well, and the bender I linked to is up to the task, it's actually right up there with dedicated size benders for the quality of the bends it makes.
BukitCase
Oregon
Your link (RobinAir) says it's discontinued
Also, been using the Swagelok and Ridgid benders for decades - haven't seen one that's multi-diameter tho. If you're gonna be doing quite a few bends (especially in 1/2" or larger) spend the extra $ and get one with the roller followers - MUCH nicer bends, and quite a bit easier... Steve
LXCam
Can't say I was referring to yours as I've never used that brand. But I do have a few including a very nice imperial that still ***** when compared to a good one. I'm glad you had great experience with it, good on you
454ragtop
Carver, MA
Well bummer that it is discontinued, when I posted the link I saw ships from the factory and didn't read down any further. There is this one on Ebay https://www.ebay.com/itm/4-in-1-180...=item2cd8798e0a:g:ivwAAOSwWJZbWt8y:rk:27:pf:0 which is the spittin' image of the Robinair, but I'm hesitant to recommend it since I have no direct experience. One buyer does mention it's a good copy of the RobinAir though. Note to self, if you see these at a swap meet, pick them up...……..
Wamsutta
Amarillo, Texas
The Imperial 370-FH will bend 3/16 thru 1/2.
Robbyj67
Grass Valley
I know this is an old thread but this is what I use to bend all my fuel, transmission and brake lines. I love this thing!
I cant post a link yet but this is their name Engineered Componets, Inc. (ECI)
tarbellb
Oregon
Looks very nice, and the pricing aint bad either.
12/20- 2-1 bender $150, 4-1 bender $180.
Robbyj67
Grass Valley
One of the features I reall like is being able to start a bend right at the back of a tube nut for a really tight bend in tight areas.
