madoc1
I need a small to medium bench drill press. only needs to handle up to about 3/8
-1/2 any recommendations? thx.
jim
jim
only needs to handle up to about 3/8 -1/2 any recommendations? thx.
jim
I see dp seems to be pointless to have. I myself have one...hardly used. I would better off sell it to get $$$ back. if i use drill and clamp set up to make it look like dp would be more practical. Just saying!
It seems a couple posts dissappeared?
I'm not sure what was wrong with what I said about those things being pretty useless compared to a real drill press...
I'm sure they are alright for hobby work, but not for fabrication. I'd like to see how well they do drilling 50+ holes in 1/2" plate... That was just normal work for my old delta.
you can never have too many tools
Now this is a drill press. 16" beaver. Old 1950s canadian cast iron. The base on it is solid. Thing is easily 250 pounds
This was 125 bucks on Craigslist....
Oh well, not worth worrying about.Yeah, what happened? I agree that they're not much use to heavy machinists or repetitive work and I saw nothing wrong with what you wrote.
Not exactly small hahaThat...is one heck of a drill press.![]()
I'm still looking for a mag drill. Those things are sweet!Yeah, some pretty disrespectful posts went down. You are completely right, drill presses are indespensible when it comes to everything. Exceptions would be mag drills and on site or quick n' dirty work.
Sweet belt grinder by the way!
I was just suggesting another option for the same price as one of those. It all depends what your doing. The op mentioned drilling 1/2" holes in steel, and to me thats big drill press territoryGuy asks for a small dp and you guys start suggesting industrial mills. Sheesh.
I got a 10" ryobi for $100 that has been great for wood and small metal (mostly related to car and motorcycle restoration). It's small enough I've had it on a flip top table, out of the way when I need the bench space. My best friend has been dragging his dad's floor standing delta drill press from house to apartment for years and usually uses the cordless drill,because the big dp is stuffed in a corner somewhere. I could probably hide mine in the kitchen.
Edit: I'm going to design a drill press/kitchen aid flip table now. Thanks Garage Journal.
larry, probably as small as 1/16.
jake, primarily metal
oldldh, no more than $200. did find a 1941 delta for $100, not sure it works. would be neat if it does.
jim
The old ones definitely are not a "pos".... Use one and see what I mean. The big one I posted actually has a cast aluminum cover for the whole top enclosing the belt, I just keep it off because its annoying to change belts.I bought a 10" WEN basically brand new off craigslist for 50 bucks. I don't have any complaints. Never heard of WEN, I don't suggest going out of your way to buy one, but it seams like a nice unit.
I believe the guy I got it from said he got it off amazon.
You couldn't give me one of those old POS drill presses with the exposed belts. No thanks. You drill press nuts are nuts. Why suggest something so old, And heavy?
