Small engine compression tester adapter
So a couple of months ago I did the "buy once, cry once" and bough the Mityvac MV5530 Compression Tester Kit. Lots of adapters !
But wouldn't you know, not one for this teeny, tiny spark plug out of a Craftsman 32cc backpack blower ! No brand on the plug but the number is 794-00082.
It APPPEARS to be either an 8mm or 10mm "fine" thread, but the M10 adapter in the kit does not fit !
Where can I get an adapter to work with my Mityvac Kit ?
ToolFanGeoff
So Cal
Old Wiz, I had the same issue - and could not find an adapter that matched. I took the old spark plug, broke the ceramic, and center electrode out. I brazed a fitting to the steel spark plug shell that adapted to hose if the compression tester. Worked great. It took less time to make the fitting then I spent looking to buy one.
Sumboodie
AK
That's an MTD part number. Crosses to a RDZ4H plug which is 10x1.0 thread.
Same size as 6.2 and 6.5L diesel glow plugs which Mityvac has an aye-dapter for.
Or MVA5501 is the actual adapter I think.
ericg
Could this be it
KnurledNut
n/a
That plug is a M10x1.00 as Sumboodie mentioned.
I have the rebranded Craftsman version of your kit and the adaptor is the same, M10x1.00.
Cant say why its not cooperating.
Sumboodie
AK
Same, I know I've done small engines, but can't remember if I ever bothered with very small small engines so wasn't sure what the kit had.
I bought mine probably near 25 years ago at Sears.
Normally easy to tell if it's got decent compression or not just from the pull cord.
