Small engine mechanic question
john.k
Brisbane Qld Australia
Thin hard (HT) steel .....welds do crack ,but typically replacements decks are costly...weld is cheap.............i would never buy a contractors mower ...full stop.
humber2
Downunder
I’m keeeping 40 year old B&S engines running down here, nothing is metric on these.
Essential tools are....
15/16 deep offset box end wrench for the flywheel nut.
13/16 spark plug socket with 3/8 drive ratchet.
9/16 6 point box end wrench for the blade holding bolt head.
1/2 box wrench if removing cylinder head.
1/2 6 point socket with 3” extension for pull cord bolt, 1/4 drive ratchet.
7/16 6 point socket for cover removal, 1/4 drive ratchet
5/16 6 point socket for governor blade removal, 1/4 drive ratchet.
1/4 6 point socket for tappet chest cover screws, 1/4 drive ratchet.
Screwdriver for air filter screw.
Feeler gauge set.
Hammer to jolt flywheel free.
Valve spring compressor.
As Taryl would say, “And that’s your dinner”
YMMV
Drunkonunleaded
Detroit Rock City
I do a lot of powersports and small engine work. 90% of the time I'm using 1/4" due to access. Personally, I'd start there. I also echo the other post for a t-handle. The ones from Motion Pro and Carlyle have a ball bearing in them, which makes spinning even easier. Rarely do I need/use a ratchet on a lot of these fasteners and if I do it's usually a roto head or flex head. Again, due to space constraints.
john.k
I have a 1976 B&S on a mower ...still runs ,but I got a new mower ,not cause I needed one ,but it has a nice seat instead of a board with 1 '' of foam .
Ohio Andy
Columbus, Ohio
I have no skip Tekton sets..
1/4" is under $100 (barely)
Their 3/8 set guess down to 1/4" so if the ratchet size is fine, $175 is a great range no skips shallow and deep, SAE and metric
Set is not too heavy. If the ratchet is too heavy, add a stubby 3/8.
I picked up a really nice combo set with no skips from SK, put with no skip, shallow and deep. It's really heavy.
If you can handle the steps, just grab your favorite set.
