Lyaec350
So it's that time of year... I'm getting the fleet of small engines ready for the winter and after facing numerous fuel related issues this summer I want to do it right to minimize trouble next year.
Engines include 2 and 4 stroke, everything from a 30cc chainsaw to a 13 horse generator...
I've been reading conflicting reports about how to winterize small engines and I was just wondering what you guys have found to work well. Is there any fool proof way of keeping these infrequently used items in good running condition? Here is what has been suggested so far:
1.) Empty gas tank, add a tiny bit of stabilized fuel and run until dry. Drain carb (if possible), remove spark plug and squirt a bit of oil into the cylinder and pull the starter a few times to distribute oil. Leave 2 stroke engines with piston at the top of the stroke to keep junk from getting in from the exhaust port.
OR
2.) Empty old gas, fill totally with stabilized fuel (SeaFoam was recommended over Stabil by my boat dealer). Logic here is that you can never get all the gas out, even by running it dry and air is what causes the fuel to go bad, so by filling the tank up full you are removing most of the air. Same procedure w/ oil in the cylinder.
OR
3.) Something else totally???
Does squirting oil in and cranking it a few times work just as well as using a fogging spray?
Sorry for all the questions, I'm pretty new to the small engine world.
OR
OR
