Small garage/shop
blonzz
SW Desert
I finally got around to assembling some furniture. It's been sitting in cartons in my other garage since 08/05.
I also hung a few pictures from the GM Photo Store I framed up. I still have a couple more to hang.
The building is 20 years old. It use to have and open attic. I got tired of the dust from our summer monsoon storms. I enclosed it last summer and laid down Lock-tile flooring. Two coats of Andeck CLEARCOAT 44 was applied. It makes the dovetail joint seams watertight.
The interior dimensions are 18'Wx28'Dx9'H
John
This is actually three pictures side by side. The woman in the middle frame is checking pistons on an Oldsmobile assembley line
Doctor Oldsmobile and Wind Tunnel Waldo
This is the building before the remodeling. It had an open attic.
I did most of the work on the gold 442 when it was resurrected in 12/03 after 18 years of garage storage. At that time my tool box was an Edelbrock manifold cardboard box! (true)
TACRick
In the shadow of IRP & IMS
Cool workspace, John!
Now for the challenge -- KEEPING it that clean and organized...:bounce:
Rick ---> who seems to get a lot of help from other family members in deciding what should be stuck in the garage...
blonzz
SW Desert
Thanks
My dads got a 68. What do you have in that?
Current build:
Oldsmobile 468 ci engine
Edelbrock Performer heads and Torker intake
10.3:1 CR
Pro Systems Pro Series 4150 950 CFM custom built for my application
Pertronix Flame Thrower HEI w/digital rev limiter
Camshaft -
239°/239° @ .050
.541" Intake Lift
.541" Exhaust Lift
110° Lobe Separation
Thorley headers 1 3/4" tubes 3" collector
Torque Tech 3" X-pipe system w/ 22" large case Aero Chamber mufflers
Flowmaster stainless steel 3 1/2" x 12" tips
TCI Turbo 400
Coan Maximum Performance 10" 3200 RPM stall converter
Strange Engineering 3" chrome-moly driveshaft, 1350 series u-joints
Moser Engineering complete 12 bolt assembly, Eaton 33 spline posi and 4.11:1 pro gears
Global West lower trailing arms
UMI adjustable upper trailing arms
QA1 adjustable shocks (rear)
Edelbrock IAS classic shocks (front)
Mickey Thompson 325/50R15 drag radials on aftermarket 10" SS II wheels
I am having BTR Performance build me a 'pump gas' Oldsmobile 455 stroker 496ci
4.5" stroke
CNC Machined Block
Velasco, light weight billet crank. Hollow mains center counterweight
Balance
Bearings coated, prepped, groved cam bearings
GRP aluminum Pro material rods
CP pistons custom light weight
Precision pin superfinished pins
Moroso aluminum pan
Titan gearortor pump
Custom grind Roller Cam
Modify cam for roller thrust bearing
Roller lifters
Edelbrock heads, completely ported, stainless steel valves
T&D shaft rocker setup
Cometic head gaskets
Ported intake manifold
ARP bolts
Progear adjustable timing chain
ATI flexplate
ATI balancer
Will push the car into the low 10's in full 3800 lb street trim
I am also converting the front over to a QA1 coil overs with adjustable shocks and adding a anti roll bar to the rear.
John
JMURiz
NoVA
Great looking 'small' garage. Doesn't look so small to me. Very nice/clean 1+ car garage!
3/4tonYJ
Central, PA.
looks really nice, i like.
then i seen the before picture. Wow, you did alot of great work......
what paint did you use on the walls?
looks like an "egg-shell flat (or semi-gloss) white"...........?
snorvet
Northern Illinois
Is that a Gladiator fridge? The guy at the Garage Store told me that Gladiator didnt make the small fridge any more. Your garage (and car) look great! That clearcoat really makes it.
B.C.
CA.
The Car Is Fantastic I Love What You Did. Thanks For All The Specs On The Motor I Love Detail. Garge Is Gr8 Too.
