R6 Racer
I am going to build a loft above the stairs that lead to the basement from my garage. (pics included) I want this loft to carry some fairly heavy weight. I will have my 60 gallon air compressor (250lbs), A sandblast cabinet (300lbs +)& either a motorcycle (400lbs) or a snowblower (less than 400) & me (210lbs). So I will want it to be able to handle 2000lbs at least.
Sides a & b will be attached to studded walls (16" on center) that are currently drywalled. Side d will be supported by a 2x4 studded support wall. The top deck will be 3/4" plywood.
Questions
1) Which way should I run the floor joists... pic1 (loft 1) or pic 2 (loft 2) & why?
2) What are your ideas for attaching sides a & b to the existing studded walls?
Questions
