small/medium sized True RMS multimeter
cheechi
Triad, NC
I am looking for a relatively small meter to put in my kit with crimpers, ends, misc DC stuff for amateur radio and other misc electronics. I have a 27/FM 87V and 88V and i am looking for something about half the size, but with as many functions as I can. I would like ammeter and TRMS if possible, but i'll settle for just TRMS if the size is right. I want one with removable/replaceable leads I don't have a good history with the small ones with built in leads.
I like the size & shape of the Fluke 101 & 107, and I may get one anyway, but neither is TRMS and the 101 doesn't do amps. It doesn't have to be a fluke but i do want one that is good & reliable. I have some extech (I think) somewhere but I can't find it, i don't think its small enough for what i want, and I'm not sure its either TRMS or has an ammeter. I don't want to go with one of the HF ones unless you guys say there is a gem among them, but some of the ones they sell fit the size im looking for.
Thanks in advance for any suggestions.
C
cheechi
Triad, NC
wow blast from the past. I've used one or really similar, but totally forgot about those. added to the list thanks.
noid
Check out the Sperry Instruments DM6850T Ultra-thin.
TRMS, ammeter, removable leads, capacitance, frequency, non contact voltage, data logging, also has bluetooth if you want to hookup and review remotely.
GeoBruin
That looks sweet. Especially the one that can use a type K probe. I have this Amprobe pocket Multimeter which has been great, and is tiny, but it's limited in some ways.
Amprobe PM55A Pocket Multimeter with Non-Contact Voltage Detection, Black https://www.amazon.com/dp/B0012IUZ68?tag=atomicindus08-20
bonneyman
Desert SW
That Sperry does look phenomenal! With something that thin you'd be able to have it one you all day, in a shirt pocket or something. Very cool!
AdAstra
Just went thru this selection process and wound up with a Brymen BM037, great form factor and the AC/DC clamp is nice, I rarely need inline current measurement.
C
cheechi
Triad, NC
See if you can find an older Fluke 112, it's got everything you need in a small package, TRMS/10 Amp/backlight/min-max it will take the T-PAK hangers too
I have a search saved on ebay for this now, i'll pick one up when i find a listing i like.
Check out the Brymen BM235.
This has been on my list for a while and i didn't realize how small it is until you mentioned it in this thread.
this one is saved for the next time i need, i am putting together a few boxes and will probably put a meter in each.
I havent used one but the Klein MM450 has some nice features and is only $61 on Amazon:
Thanks for the suggestion this is ultimately the one i went with. I have one of the original USA made MM6000 and i like it ok but it's no fluke. i think this one has more features than it though. we will see once it arrives, whether i keep it or get a 112.
tak1313
Another vote for Uni-T. They are well regarded in various electronic forums including EEVBlog.
Dakotadadv8
I have the Klein Mm400 from HD not bad but upgraded to Fluke 117 from HD. Big difference.
Rabid Badger
I had one of these. That always-on backlight eats batteries. If you try to use rechargeables it immediately shows low battery and quickly refuses to work. I don't like using alkaline batteries in my meters because they always seem to leak. That leaves Energizer lithiums, which are quite pricey.
Aside from the battery issue it's a nice meter. Solidly built, good input protection, etc. The indicator lights on the input jacks are a nice touch.
KnurledNut
n/a
Have you tried using it in manual low brightness mode?
My MM720 uses the same auto-brightness reverse-contrast display that has the same manual mode.
Rabid Badger
I gave it to my neighbor. He needs a meter maybe twice a year, so the battery drain won't be a problem for him. With the Energizer lithiums in it he's set for the next decade at least.
I'm making do with my Fluke 87V & 117, Brymen BM869S & BM235, Extech MA435T and Uni-T UT210E. I do have my eye on the EEVBlog 121GW, though.
GeoBruin
In doing AC power work, unless specified in documentation, the specified voltages are always RMS. Switch to signal work and voltages will be peak to peak for the most part. There will be some circuitry that does require measurements in RMS.
A nice succinct explanation from Rockwell Automation.
American Locomotive
Rhode Island
Hi What would you all use true RMS for?
Standard "averaging" multimeters that can measure AC only work properly if the AC signal is a perfect sine wave. Generally speaking, perfect AC sine waves only happen on clean mains power. For just about anything your average electrician or homeowner would do, this is completely fine.
If you're doing electronics work on things like radios, amplifiers, computers, etc..., they can generate AC signals that are not perfect sine waves. They could be square waves, half-waves, distorted sine waves, or anything in between. A standard "averaging" multimeter trying to measure one of these AC signals will display very wrong numbers. TrueRMS multimeters have a special circuit that is able to accurately calculate the "True RMS Voltage" for these irregular AC waveforms.
jayemm
up high down low
You need more meters.:rolleyes:
BrandonV
Arizona
True RMS is also a requirement for testing certain types of AC wheel speed sensors. I know GM used to recommend the 87 and not the 88 for this reason.
jayemm
up high down low
Wasn't aware of that, but do remember getting some millivolt readings jumping around (non RMS meter) when turning the wheel by hand while under my Buick repairing broken wheel speed sensor wires. A little soldering trumped the trouble and expense of changing out a wheel bearing assembly.
tak1313
Some of us have odd collecting hobbies :).
i collect all kinds of stuff - not because I want to collect them, it's more because I don't get rid of old stuff when I buy a new one...
My wife complains about my "collections" all the time.
BrandonV
Arizona
has anyone bought Brymen in the USA? I've read about just two sites where you might can get them.
So in the United States, the best options are to buy a Greenlee (certain models are rebranded Brymens) or a EEVBlog meter.
Otherwise, if you're looking for a particular Brymen model the best place to buy IMO is TME.
