Small quality tools
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Hi.
I sometimes work with watches, instruments and other small stuff. Not so easy at 68 since my eyesight is not up to scratch, but with the aid of a good USB camera connected to a LCD screen it is still something I enjoy.
I have some old watchmakers tools. All tools are +50 years old.
Best regards
Ola
Haveblue
kansas
Thats cool! Thanks for sharing! I would like to see more pics of your tools and projects! I've always been fascinated by small machines like watches and actuators
Davefr
OR
Hi.
I sometimes work with watches, instruments and other small stuff. Not so easy at 68 since my eyesight is not up to scratch.
Ola
Another option is to get an Optivsor and mount a Zebralight to the brim. The best Zebralight to use is the natural light floody.
M
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
ChevyEFI.
The broaches are used primarily to create a bearing hole in brass, so that the slow moving shafts get a low friction surface. The drilled hole is broached first from one side so that the shaft can enter abt halfway thru. Turn part over and broach from other side so that shaft just slides thru. Play is around 0,005 mm when correctly done. The shaft is lubed with "hoof oil" , and only a very small fraction of a drop is enough for many years.
The broaches are great for other purposes too, and can be used in normal steel also at a thickness up to 1,5 mm. They are perfect for adjusting a worn out( elliptical) hole in a watch part. The design makes them self center so that the origo of the widened hole remains, which is quite astonishing.
One non-watch task at which they excel is to ream up holes in a thru-plated PCB. When replacing components, it is quite common that the new part has a larger dia pin. Drilling up say 0,1 mm *****. With a broach like this it is easy and the risk to damage the thru-plated hole is zero!
The design of the broaches is intricate. They are made of spring steel that is polished after grinding. The penta-shape is asymmetrical, each ridge is a few degrees off of 72 degrees. This helps the broach to make a very round hole.
They are made in Switzerland and the label in the box is in French, German and English.
As to eyesight, a pair of dentists glasses ( with built in "microscope" ) that has an astonishing depth of field and perfect three-D view would be perfect. However , they start at US$ 3k, so I guess I wait until I stumble over a brown envelope somewhere.
Ola
Andy Griffith
Western WA
That's an excellent idea, Dave. I use my Optivisor all the time but almost always have to add some light to the situation as well.
You don't happen to know the model number of your Zebralight? There seem to be a several options for neutral white flood. Does yours use AA or 123 batteries? Is that the stock headband holder that you flattened out and fastened to the top of the optivisor?
Thanks
http://www.zebralight.com/Discontinued-Products_c_18.html
http://www.zebralight.com/Headlamp_c_7.html
