Small screwdriver bit holder/box
Robinson1
Kentucky
Does anyone make a small screwdriver bit holder/bit box that's small enough to drop in a tool belt and not take up the entire pocket?
I'm constantly working with different type fasteners. And keeping a bunch of single bits in my shirt pocket is ******* me off. Constantly falling out every time I bend over, and seems like I have to pull every bit out to find the one I need.
I regularly use Phillips 2 and 3, square 2, T20 and T25. Looking for something that could hold two bits of each size in a super compact package and not be a pain in the *** to use. If it could also hold a 3 inch magnetic extension that would be a plus as well.
Closest thing I've been able to find is a clam shell type case at the local true value. Sort of looks like a mouth guard case. Holds about 50 bits. I don't want or need that big.
Tried an altoids tin. They always find a way to open in my tool belt and dump the bits. Not ideal at all.
ihateminimumwage
Dewalt DWAX100 is pretty compact (4" x 3" x 1-1/2"). Might be more than you need, holds an extension and 30 bits. Solidly built as far as portable bit cases go.
LB-1911
Northwestern Il.
Two possibilities -
1/4 in. Bit Holder ULLMAN BH-2
Bosch T4021 21-Piece Screwdriver Bit Set
LeeG
Phoenix, AZ
I really like the Festool Twinbox bit holders. 2 halves, each holds 5 bits. The two halves come apart easily to clip onto a pocket or whatever. The bits are held securely, but come out easily.
$12 with bits.
Available on Amazon or from Festool Resellers
AE2
Atchison KS
Prescription pill bottle. They come in lots of sizes so you can find one that works. The label should peel off easy. If you break it no big deal. I use them for bits and also misc screws.
thertel
T45
PB SWISS - They are very low-profile, they hold secure, easy to remove, and don't trap moisture. try to get the singles on amazon for $3/each when in stock from count on tools., and get free shipping via prime/add-on.
