Small Sizes For Security Torx Plus Bits?
Solid Lifters
Inland Empire, SoCal
I need some small driver bit sizes in 1/4" 25mm or longer for Security Torx Plus. The smallest size I have is IPR-8. What choices do I have? Am I stuck with buying screwdrivers instead of bits?
Worse case scenario, I could use some pentalobe bits. But, it's not the same as the above. Again, in very small sizes. What are my choices here?
If I don't have bits as an option, what drivers should I get for what I need?
cbracer
Costa Mesa, CA
To be honest, I don't think the 5 lobe torx plus come smaller than 8 in security type. Maybe I'm wrong, though I've seen the torx security down to 3 or 5 as the smallest.
Pantsfall_McFixit
Saw your avatar, Wiha makes bits only down to IPR8. Quickly searched through Felo, Elora, and Hazet catalogs but didn't find bits.
Edited, brainfart, forgot to search security bits.
CWP1616L
USA
I'm not sure I'd want a screwdriver bit smaller than T8. Depending on the handle size, those bit drivers can put out a lot of torque.
