Small utility sink?
nissan_crawler
Wichita, KS
I'm looking for a small utility sink (plastic or stainless), preferably not bigger than 15"x15", but it would be nice if it was 12" or so deep. I haven't been able to find anything, any ideas?
CraigFL
Panama City, FL
Have you searched for a "bar" sink commonly used for home wet bars?
Also, somtimes these type of sinks are used in laboratories --- maybe industrial supply house...
N
nissan_crawler
Wichita, KS
yeah, but bar sinks are usually 5-6" deep, hoping for more. If worst comes to worst, I might buy a poly water tank and cut the top off and use it for a sink.
jgwood
look for a medical sink did a remodal for a medical center and the sink we had to put in was 15+15+12 nice little sink
GRegg
Finley
Cincinnati
try the ones that are usually put into smaller rv's they are small dimensionally but fairly deep
trainer
Northern Ontario, Canada
One option is to make one.
I once made a custom sink for a darkroom using 3/4" exterior plywood covered with a couple layers of fibreglass mat and polyester resin. It held up well for over five years. If I were to do it again, I'd look into using something like West system epoxy.
boiler7904
NW IN
You can probably get what you're looking for locally from a commercial plumbing supply house. Restaurant suppliers would also have access to custom fabricators.
Just Mfg. is a company that we use from time to time with good results.
Just Mfg Self ******* SS Deep Sinks
RbrtAWhyt
North East Georgia
mcpt1
Whitmore Lake,MI
i was just at a locally run habitat for humanity resale shop here in MI. They had a large variety of used sinks for cheap, you might want to see if they have a similar operation near you. Local recyclers also run used goods operations. My 3 car garage is being built now and I think these places will be great for outfitting numerous components cheaply
Gary
arthur1920
sounds like a small laundry sink, plastic, deep, stands on four legs. I used to see them in adds all the time at home building stores?
N
nissan_crawler
Wichita, KS
laundry sinks are too big, even the small ones I've seen. I'm trying to do this cheaply, but may have to settle with buying a $100 unit.
anojones
I had the same problem, looking for a deep small sink and just couldn't find what I was looking for in a reasonable price range. I ended up buying an inexpensive bathroom cabinet/sink combo- not deep but at least gives me a sink for cheap until I find the right tub.
N
nissan_crawler
Wichita, KS
I took roberts advice and bought this sink: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=ADME:B:EOIBSAA:US:11&Item=170277436184
I also got this: https://www.mountainside-medical.com/product.cfm?productid=1E4F2EC2-ACA5-7C91-1FCC72060B64FDAF
Hopefully it'll never get used, but it seems good practice to have one in a shop.
Brad54
It's a little bigger than you asked for, but I installed a stainless 20x20x10-inch deep sink in the laundry room. Installed in with a vanity counter top and cabinet underneath (laundry room also has a commode in it, so it's an additional bathroom). That big really allows us to get some big things in there to clean, plus while I'm washing my greasy hands, I can wash them down in the sink, keeping splash and grime off the walls, etc.
I got the sink at Home Depot. I also drilled an additional hole in the flange by the faucet ports to run a kitchen sink sprayer.
-Brad
sberry
Brethren, Michigan
I like the bigger utility tub type, they are about 15$ or so at box stores. I modify them to use a single handle kitchen faucet. I have 2 in my shop, even tossed one and put in new when it was difficult to clean. This one is on the far side of the shop, keeps a lot of the traffic out of the regular bathrooms.
kbs2244
I have done it sberry's way.
I chuck out the supplied legs and build a sturdier 2x4 and plywood box for a stand.
I like to have hose threads on the faucets, one hot and one cold, and about 12 inch long hoses dropped into the sink.
I keep a 2 gal plastic pail underneath for jobs that need some soaking.
sberry
Brethren, Michigan
As I said, I have 2 of them, one in the main traffic flow, super convenient.
N
nissan_crawler
Wichita, KS
Like I said, I couldn't use a utility sink that size. Honestly, the one I got is still bigger than I wanted, but with the backsplash, and the faucet and drain included for $65 shipped, I couldn't say no.
