I was given a newer 8000 btu window AC unit. I thought I'd put it in my 700 sq ft garage to use in addition to my dehumidifier that I run during the Summer months. I know that high humidity makes you feel hot, I was thinking the smaller AC unit used in conjunction with the dehum will provide decent relief. The garage is shaded for a good portion of the day. The first day I installed the AC the garage was 84 degrees on a 90+ degree day. Within 1.5 hours the temp was down to 78. Now I am trying to figure out the right balance between the units, run both the dehumidifier and AC on higher settings or both units on lower settings, causing either or to work harder and compensate for the other. I know the correct answer is to get a properly sized mini split, but I was given both of these units and if I can manage to get by with them it would take many years to make up the difference in $'s saved if I spent the money now to add a mini split. Any thoughts on this?
