Smart light switch wiring
ollie76
Nova Scotia
Evening folks,
I replaced a light switch in my living room this evening with a "smart dimmer" switch. It was pretty straightforward, two pole on-off switch removed and the dimmer installed. Just had to tie into the existing neutral, that was the only difference.
However, I did notice that the removed switch had no ground attached to it. Just a black and a red. I could see other bare copper wires pigtailed to the electrical box, but no direct wire from the switch itself. Not having any spare wire, I did not attach the new switch green terminal to the ground wire pigtails. Is this wired up wrong?
PedroEvo
Toronto
Evening folks,
Yeah most of the new switches require a neutral hooked up now. Even by code as of this year when you rough in a house every box has to have a neutral incase the home owner changes it at a later date. As long as the box is grounded that’s usually sufficient. It’s nice to have a ground onto the new dimmer as sometimes they can go a bit crazy. If you see anything unusual I would just add it if not it’ll be fine.
Git
S Cal
If I was installing a new switch that had a provision for a ground wire then I would add a ground wire. Better safe than sorry
AntonLargiader
Charlottesville, VA
If it was a metal yoked switch in a metal box it probably self grounded. The Wemo smart switches I’ve used have plastic yokes.
You should connect the ground terminal to the bundle of grounds in the box.
7635tools
Southeast Wisconsin
There are exceptions to the neutral rule. You don’t always have to have one in the box. Around here a lot of jurisdictions require conduit and there are exceptions with conduit.
PedroEvo
Toronto
Nope, in Toronto Canada every single box needs to have a neutral as per this year. He’ll actually check during rough in now days.
7635tools
Southeast Wisconsin
Well here in the states there are exceptions in the NEC.
