Smart Switches
Skooterj
Indiana
Anyone know of a smart switch that is an actual single throw? Everything I've found is a momentary, push the bottom to turn both on/off.
niget2002
Josephine, TX
Not sure how you can have on/off function like that while allowing the switch to also have control.
I was thinking the same thing.
If you manually switched it 'on' and then later on automation switched it 'off'... what would cause the physical switch to go back to the 'off' position?
Metal-Marc
Foothills of the Adirondacks
The Leviton smart switch looks like a regular Decora switch, but it's a momentary switch. It's not an on/off position like a regular switch.
Skooterj
Indiana
Hmm, hadn't thought about that. Small motor. Guess I'll stick with my TP-Links.
