Smoke alarm with remote sensor?
Jeffksf
Cleveland Ohio
So I ordered some new smoke alarms for my house and got to thinking what about my detached garage? Do they make a smoke alarm with a remote sensor so if something started cooking in my detached garage the alarm would go off in the house? What would my options be otherwise?
Stuart in MN
Minneapolis
Kidde makes a wireless smoke detector that may work, but I don't know what it's range is. http://www.kidde.com/KiddeWireless/Pages/KiddeWirelessProductDescriptions.aspx . However, smoke detectors are generally not recommended for use in garages, since they can be fooled by dust or exhaust smoke - typically, a rate of temperature change sensor is used instead; it detects a rapid change in the room temperature when there's a fire.
6768rogues
Western NY
Check the listing on any smoke detectors you consider. Ionization (most common residential) do not work well in cold temps and the listing will have a temperature range. You might be able to use a photoelectric smoke detector, but check the temp tolerance. Dirt and dust could be problematic. As Stuart said, you might need a rate of rise detector. Bear in mind that a rate of rise detector is a heat detector and not a smoke detector. It is a lot better than nothing, but is not considered to be a life safety device.
J
Jeffksf
Cleveland Ohio
THats ok, nothing I care about is living in the garage, I should say no living things are in the garage that I care about, but a couple inanimate things are in there that I care about
artrem
We have these Kidde wireless detectors in our house and they work great. I bought one for the garage but then I read as stated above, that they can be triggered by exhaust. Since we have a wireless security system, I was able to have a thermal rate of rise sensor wirelessly tied into that system.
bygasper
My smoke detectors are wired into my alarm system in two of my buildings. I get notified of any reason the "alarm system" is triggered. This includes smoke detectors going off (doesn't actually set off the alarm). I travel for a living...I'll get a call anywhere that I have cell signal.
J
Jeffksf
Cleveland Ohio
Also do you know about the dual sensor smoke alarms? My fire chief informed me about them. They result in far less false alarms due to cooking etc. I had never heard of them. Smoke alarms also wear out like any appliance and they should be replaced periodically.
