StreetThisEVO
I am looking to replace all of my homes smoke / carbon detectors soon. I'd also like to but one to my detached garage as I just added (2) Mr. Heater natural gas heaters.
Here is what I'm thinking for the general layout:
House
(Main Floor) - Ceiling mounted battery powered smoke / carbon detector (centrally located in my hallway).
(Basement) - Ceiling mounted battery powered smoke / carbon detector (located centered between the electrical panel and my furnace / water heater / & AV rack).
Detached Garage
- Ceiling mounted hard-wired 110 Volt smoke detector (centrally located in the middle of the space).
- and -
- Wall mounted 110 Volt plug-in style carbon / explosive gas sensor with LCD read-out (centrally located between the two wall mounted heaters).
I'd like all 3 detectors to talk to one another (wirelessly would be best). This way if I'm in the house and something happens in the garage I'll know about it. The issue is I would like the garage smoke detector to be deactivated when I'm in there working and the lights are on. I will eventually be installing motion sensors to trigger the lights to save energy if left on and nobody is present.
I do a lot of cutting / welding / sanding / etc.. that would most certainly trigger any smoke detector to go off. I'd hate for it to be 11 pm at night and the alarms in the house go off scaring my wife to death.
From my brief research most all of the hard-wired detectors I've found that can be linked to other similar devices have some form of battery back-up. And if the battery back-up is removed that detector will beep until it is replaced.
Has anyone ran into this before? Worst case I don't put a smoke detector in the garage. But I'd feel better at night knowing there is one there and I might be able to do something to prevent damage in the event it were to occur while I'm home.
Thanks!
House
Detached Garage
- and -
Thanks!
