Smoke testing for vacuum leak in turbo engine.
atikovi
Suburban Washington DC
I have a 2013 Fiat Abarth that is constantly throwing a P2172 for vacuum leak detected. I've smoke tested it 3 times with a conventional smoke machine and found no leaks. Think I did it correctly by putting the smoke into the duct that goes to the turbo after the air filter, but I didn't block the tail pipes since there shouldn't be direct air flow there.
Smoke machines use low pressure, like 1/2 psi but turbos make 10-15 psi. Do I need a tool that will test at high pressures? I saw Lisle makes this: https://www.lislecorp.com/specialty-tools/69910---turbo-air-system-test-kit-wsmoke-adapter-14pc
toplessHO
central florida
block off intake,exhaust and any vents in fuel tank
apply smoke and see where it comes out.
the leak may not be external ,example vacuum leaking into exhaust.
Steve_P
Turbo owners do pressure tests. 15 PSI or more. Do a Google search.
2ndGearRubber
Pittsburgh
But then it's not a vacuum leak if the booster isn't open to the atmosphere?
If the booster is under vacuum on both sides of the diaphragm, you can draw in unmetered air. Typically a small tear is what does it, and sometimes the leak will only be present when pressing the pedal.
2ndGearRubber
Pittsburgh
No, just block the vacuum line at idle and see if the trims change.
Again, in global obd2 data, fuel trim short and long term at idle and 2500+rpm. If trims improve you likely have a vacuum leak issue, if it doesn't you have a metering or supply issue.
Randomly checking parts isnt going to find your problem.
2ndGearRubber
Pittsburgh
Electronic throttle actuator and map actual values are compared to calculated values. If they differ beyond X percent, p2172 sets.
Wrench97
Southeastern Pa
Are you running a stock Throttle valve or a performance aftermarket unit?
If you smoked it and do not see a leak I'd be looking at the map sensor reading while driving or watching the TPS sensor on the scan tool for drop outs.
A
atikovi
Here is a video of live data at idle and 2500 rpm with vacuum line connected:
Wrench97
Southeastern Pa
6 PSI manifold pressure at idle and 3PSI @2500?
Where you driving it or just revving it up?
Again is this a stock setup or aftermarket parts are involved?
Wrench97
Southeastern Pa
Vacuum gauge says vacuum and map sensor says pressure, I would check the wiring to the map(IE unplug it while looking at the scan tool and note what if any change their is) if it looks ok, change the map. The readings change so chances are the wiring is ok.
quattroman
Scotland
I pressure test to peak boost pressure, I have had a couple of weird leaks that only seemed to open up at higher pressures.
2ndGearRubber
Pittsburgh
Fuel trims say no vacuum leaks, now anyways. You're averaging +/- 5% or so. As others mentioned the purge could be sticking open.
Does it make full boost pressure wide open throttle driving down the road? That'll tell you if it's an issue with actually loosing/leaking pressure, or an issue with the throttle. Can you compare a boost pressure sensor against the MAP value for a sanity check of both?
